Hi guys,
As part of our contract, we are installing new natural gas meters with integrated pulsers that give us a pulse every so many cubic feet of gas.
The pulse that we get from the meter will then be used for utility logging.
Internally to the meter the circuitry is an open collector output that will drive itself low when we get a pulse. The source voltage will come from the RTU collector panel. Pretty standard stuff.
The cable going into the meter is connected via a standard appliance crimp-type connector and there is no provision for wiring this using explosion-proof methods.
The question that we have here at the office is: does this meter have to be connected using intrinsically safe methods? The device feeding the sensor is not intrinsically safe, so there is a chance of ignition should the wires going to the meter become shorted.
Personally, I think that it's necessary, for CYA purposes if nothing else (if someone takes out the meter with a fork truck, then the wires to the meter will probably short out and possibly cause an explosion).
The argument against installing this as an intrinsically safe circuit is that we ignore the 800 lb gorilla in the room, that being the electrical service right next to the gas meter.
Thanks for your help,
John
John
