codequestion
Banned
- MD, USA
I have incoming utility that is feeding main distribution panel in multi occupancy building. The system grounding is at the main distribution panel which has neutral bar and ground bar. The neutral bar in main distribution panel has individual conductors each individual seperate conductor from neutral bar going to following: building steel, water pipe, ufer, ground rod, and gas pipe. Is the connection to gas pipe USING GAS PIPE as GROUND ELECTRODE? Or the connection BONDED to GAS PIPE and NOT using as ground electrode?
