buck
- California
Help guys/gals.... I say equiptment ground to any gas appliance is sufficent for gas pipe bonding. What are your local jurisdictions take on this? Getting heat from inspectors who say NO. They say the code specifically says to bond gas piping per 250-104(b)and the only piping allowed to be bonded through equiptment ground of circuit is what is refered to in (c) as "Other Metal Piping".
Even if the gas line required a seperate bond wire from any component of the grounding electrode system, section (b) doesn't reference you to a Table to base the size to be.
Anyway, I did a search om the Holt forum but would like a concensus or if someone has a solid reference for proper interpretation?
Thanks in advance...
