Gas piping in residential wiring.
Electric Doug
New member
An inspector recently failed a house we finished because the ridgid metal natural gas pipes were not grounded, and gave the code referance of 250.6. Objectionable Current over Grounding Conductors. Can anyone enlighten my intellect a little. And is there a good electrical dictionary I should get to explain some of the terminolgy in the NEC besides the hand book.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Read this thread
http://forums.mikeholt.com/showthread.php?t=82829
mvannevel
250.104(B) requires metal gas piping to be bonded, but it allows the equipment grounding conductor for the circuit that may energize the piping to serve as the bonding means.
infinity
New Jersey
Journeyman Electrician
This has always been he accepted practice here. The EGC supplying the gas appliance(s) effectively bonds the gas pipe.
mvannevel
Same here, but it was nice when they included that language for gas piping in the '02 cycle. I still see a lot of contractors that will run a full size bonding conductor to the gas piping though.
The wording of 250-104(b) for bonding the gas piping in the '99 Code was extracted from the Fuel Gas Code. My understanding is that it was the intent of the Fuel Gas Code that the circuit supplying a gas appliance was suitable for this bonding, but it wasn't written that way in the '99 Code. Somewhere around the office I have a Formal Interpretation from NFPA to that effect. They fixed the wording in '02 and everybody could relax. That is until Gastite issued their tech bulletin for CSST...
james wuebker
Iowa
The only problem that could come up is if the pipe had a die-electric type fitting on it then you would have to put a jumper on it.
Jim
raider1
Logan, Utah
That has always been my pratice as well.
Yes, but the jumper would only have to be sized to match the EGC of the circuit that feeds the gas appliance.
Chris
james wuebker
Iowa
Chris
Yes, you are correct Chris.
Jim
iwire
Massachusetts
Jim
If there is a die-electric fitting why would the gas line still be likely to be energized?
In my opinion 250.104(B) does not require a gas line that is not electrically connected to an electric appliance to be bonded.
250.104(B) only requires we bond 'other metal piping' if it 'may' become energized.
If the pipes are not connected to electric equipment it is unlikely they will become energized.
If they are we will also have to start bonding metal waste pipes and down spouts.
