laketime
Looked at a job, residential 10kw generator, the customer bought and set the generator. The propane line was run to the unit but the gas guy did not install a regulator at the generator like I usually see. The owner just wants me to hook up the unit and see if it runs ok without the regulator. Do you think that is an issue not having a regulator at the generator and also not having the pressure checked before running the unit?
