We are trying to write a specification for grounding and surge protection for Telephone Entry Systems at a remote gate (those boxes you drive up to and select a resident, call, and the resident can open the gate from theor phone).
Typically, from the Entry System, there are underground conduits to the Gate Motors- one as a source of AC power, and one low-voltage conduit for the relays, and another conduit to the main building, which contains the telephone line, and often a data connection for additional gates, etc.
All of this is usually well over 100 feet from the Main Service Entrance, and many of the systems are in the Southeast, where there is much lightning activity and high ground resistance.
The question is whether it is best to:
1. Install a ground rod next to the Entry Panel
2. Ground the Entry Panel to the local electrical service ground with a heavy ground wire
3. Do both, and bond the ground rod to the local electrical service ground.
