Good afternoon folks,
I work in an engineering lab. I cam currently working on a project that brings in a 110VAC power cord into a simulator. This cord plugs into a receptacle (plastic) which isolates it from the metal chassis of the simulator. From the receptacle, I have run a Green/Yellow 18 gauge wire from the receptacle ground terminal to the metal chassis of the simulator.
My supervisor posed the question that he believes the NEC states that the gauge of the wire traveling from the receptacle to the chassis must be 1 gauge larger than that which is carrying the voltage from the wall.
So, basically, the cord that I plug into the simulator has three 18AWG stranded wires inside. According to him, I must use at least a 16AWG stranded wire from my receptacle to my chassis ground stud.
Can anyone comment on if this is true? Can I use a 18AWG to the ground stud just as the cord has a 18AWG coming in? Or do I need to go one bigger? I would appreciate a reference to the NEC as to what the standard is. That way I can print that particular bit of code out and bring it to him as proof.
thank you
thank you
