topend
- Parma, Ohio
I recently wired a friend's garage. The power to the garage is controlled by 3-way switches, supplied by a couple of 12/2 UF cables (a neutral used in one cable and the gobees in the other). Out of the common on the 3-way in the garage I went to a junction box ran a set of conductors to the lighting and a set to a GFCI recept. From the GFI I fed through to 8 additional receptacles. Initial problem was that I plugged my 3-pronged circuit analyzer into the GFI (and downstream receptacles) the push to trip button on it did not trip the GFI, but flashed one additional light on the tester.
It was late and I told him we'd figure it out later. In the meantime, he replaced the GFI and now as soon as there is a load (table saw) the GFI trips. Any ideas?
Thanks.
Thanks.
