I am running into a Spare Parts Conspiracy problem. I am relamping some outdoor compact fluorescent fixtures that were made by Regent and which I had installed about 2.5 years ago. These are some of the problems:
1. General Electric compact fluorescent triple tube bulbs are somehow about 1/4 inch longer than everybody else's bulbs. The original bulbs were Sylvania or Philips or Cooper 26 watt triple tube 4 pin base. The generic part number is F26TBX/SPX41/4P for the originals. The only thing that I can get locally is General Electric which is somehow 1/4 inch longer and sometimes does NOT fit into the fixture. There is a minor modification involving slight bending of the sheet metal on which the lampholders are mounted and that allows the bulbs to just barely fit.
2. I am getting about a 50% lampholder failure rate including inability to retain the wires. There is a make of CF lampholders that is junkier than Leviton.
3. I am getting a more than 60% ballast failure rate. Regent made the ballasts of had them brand name labeled.
All told, the next outdoor compact fluorescent fixture installation will use "incandescent" fixtures with compact fluorescent refit bulbs. At least I get a new ballast with each bulb and these seem to be very reliable as far as cheap Chinese junk goes.
