FrancisDoody
- Durham, CT
I have installed a raintight GE 8 space panel on a telephone pole to feed my pond aerators. This is an overhead two wire service. The panal is the standard main lug with an isolated neutral. I am not worried about creating parallel neutral return paths to the main panal. I have connected the equipment bonding conductors to the neutral bus. I have driven a ground rod and attached it to the neutral bus. My concern is that the metal enclosure is not bonded. The neutal bus is set on plastic mounts. Should I tap a 10-32 screw and use a lug connector to install a 6 awg bonding wire between the lug and the neutral bus?
Edited 6/27/2005 11:55am
To eliminate confusion the two wire conductor is really a three typical wire cable system made up of 2 insulated conductors and a messenger. This was not made clear in the original post.
Thanks,
Fran
[ June 26, 2005, 11:57 AM: Message edited by: FrancisDoody ]
Thanks,
Fran
