Hi all,
I have a project that needs to feed a new power mini zone from one of old GE MCC. A GE breaker will be installed inside one of the GE MCC cubicle to feed the power minizone and have a capability to trip the breaker from outside of the cubicle. I wish the cubicle is drawout type but it is hinged-door cubicle (50 year old model). I wasn't able to locate and read off the tags however, I got the read-off from one of the existing installed breaker in the MCC. It is GE TF136020 breaker. It will feed 1 ph,7.5KVA Minipower zone (one has combination of built-in transformer & panelboard). The problem is that I can't find any vendor or supplier (Los Angeles Area prefer) to provide the breaker along with its hardware mechanism. It needs to have a shaft or metal linkage and handle to trip the breaker from the outside. If by chances, you guys know where can supply all this (the breaker, shaft,and accessories) give me a link so I can check them out. Thank you
