Grouch
- New York, NY
I came across this in an electric service room. if you look at the attached picture, the green wire is the GEC, tapping from the neutral terminal in the service switch (towards the top of the pic) and then connecting to the cold water pipe below (pipe not seen in pic).
However, this GEC is also bonded to the service switch enclosure... you can see where they stripped the wire and bonded it, near the bottom of the picture. Is this necessary? or it against the NEC / a violation? I thought the GEC has to run straight from the neutral or ground terminal in the service switch to the grounding electrode.
