Does the GEC need to be brought to the main service disconnecting means first in order to comlpy with 250.24(A) (1)? Have a retro job where the GEC is currently run to a 300A main breaker panel which before was the first panel after the CT cabinet. Now a service disconnect has been added to the building exterior and that in turn feeds that first panel. Am I wrong in calling that panel now a sub panel? Not a big deal to change it just not sure if it needs to be. Thanks. FWIW this is a 120?240 Delta 3P system.
