The device referred to inthe last post is called a "Kenny Clamp". An inspector in this area "invented" the clamp and had it patented. By what I consider as a "creative interpretation" of the NEC he determined that such a device is required. As far as I know, the jurisdiction in which he works is the only jurisdicition requiring such a device. Since this device secures the grounding conductor to the panel, I question the need to continue the conductor to the ground/neutral bar, but the "inventor" insists that it is still needed. I haven't heard of any housings burning down or persons being electrocuted because the grounding conductor was routed through on of the small knocouts in the panel or brought through a 1/2 inch knockout using a bushing or romex connector.
