I've been asked to wire a residential boat dock. I would feed a panel out on the dock (340' from the shore) to provide power for boat lift, lights, and receptacles. All would be GFCI protected. I called the inspector to ask what particular things he wanted to see before I started (new locale for me). He indicated he would require GEC for the panel run back to a ground rod at the shore. He cited 250.32, the dock is a seperate structure.. The panel is fed from the shed which is about 7' from the start of the dock. The panel in the shed has a grounding electrode sytem, but this will not meet 250.32 as the dock is a seperate from the shed. I don't see where running a 340' gec to a ground rod that is 7' from the ground rod feeding the panel gains anything. Has anyone encountered something like this? Any thoughts or ideas are welcome.
