GEC passing thru grounding bushing
Why can't the GEC pass thru a grounding bushing before landing on the neutral bar in my service panel? In my MH- understanding the NEC 2020, there is no graphic showing this, only a 2nd conductor from the neutral bar to the grounding bushing (fig 250.51 pg. 248)
Are you asking why can't the GEC connect to the grounding bushing? If so the answer it that it can. It is also permissible to install a separate bonding jumper to the bushing.
How about this:
Good explanation. Also the larger diameter of the steel conduit decrease the impedance due to skin effect (as described in the IEEE green book)
