If the GEC is in metal conduit and a pull box is used a grounding bushing is used where the GEC enters and leaves the box. Does the GEC itself need to be connected to the screws on the bonding bushing, or can a piece of wire, the same size as the GEC, be run between the bushings and then crimped to the GEC?
