Re: GEC rod and water pipe
Originally posted by physis:. . . the answer was sort of like that's just how you have to do it.
The following things are different:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">1. Things that the NEC requires, as a minimum to create a safe installation.</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">2. Things that a local jurisdictional authority requires, even if they had not been required by the NEC.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">3. Things that an engineer conveys in plans and specifications, which then become requirements, even if they had not been required by the NEC.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">4. Things that an owner requires, even if they exceed NEC requirements.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">5. Things that the NEC permits, but does not require.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">6. Things that the NEC conveys as a Fine Print Note, and that it therfore does not require.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">7. Things that you were taught by the Master or Journeymen under whom you studied the trade, even if they exceed NEC requirements.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">The only items on this list that you ?have to do,? in order to meet code, are the first two. Whether or not you ?have to do? items 3 and 4 is a matter to be determined by your contract, and have more to do with whether or not you will be paid for the job. Items 5, 6, and 7 are
never ?have to do? items.
I would place the other contractor?s statement of ?that's just how you have to do it? under category 7.
