electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Consider a single (or paralleled) 400A conductor set between a two gang meter without disconnects, and the weather head. After the meter, one 200A set feeds a 200A service disconneect in/at the structure the 2 gang meter is mounted to, and the other set feeds a remote separate structure and 200A service disconnect per 230.40 E3. Can the GEC at the first structure be sized to the KCMIL of the 200 amp set that feeds that structure's service disoconnect or does it need to be sized to the KCMIL of the riser? I am leaning toward the latter.
