shortcircuit2
- South of Bawstin
A solar system is installed on the roof of a building with a existing 200amp utility service with a #4 copper to the metal water pipe. (note that the largest DC system conductor will be a #2 copper conductor to a combiner box)
When using method 690.47(C)(1) for a GEC system for the utility interactive inverter grounding system, and I install ground rods as my new electrode...250.166(C) allows a #6 awg copper to the ground rods from the inverter.
Then 690.47(C)(1) says to bond the DC grounding electrode to the the existing buildings AC grounding electrode with the LARGER size of the existing AC GEC (#4cu) or the DC GEC (#6) as specified in 250.166
So you would have a #6 copper to the ground rods and a #4 as the bonding jumper? Is my interpretation right?
