Hi Guys,
One of the questions that I occassionally get from electricians is in a case where the first point of disconnect is at the meter socket whether the ground electrode conductor from the water pipe can be installed in the service entrance pipe with the service entrance conductors. I don't believe that NEC disallows this, but I have concerns regarding parallel path and the grounding of the panel. Provided that each end of the service entrance pipe is bonded properly, is it acceptable to consider the panel as equipment grounded via the service entrance pipe? My interpretation of NEC is that if the first point of disconnect is at the meter socket, the neutral to ground bond is established there and the service entrance pipe could act as an equipment ground to the panel.
Thanks,
Creig
Thanks,
Creig
