kshah
- Irvine, CA
Hi all,
I have been questioned from some plan checkers as of late regarding the sizing of the ground conductors on my plans. I need some clarification regarding the use of the equipment grounding conductor and the grounding electrode conductor. There are a few qustions, at the main switchboard, is the ground calculated by the size of the feeders from the utility or the main disconnect? At the panel coming from the main switchboard, is the ground calculated by the size of the main breaker? When a step-down transformer is introduced, is the ground introduced by the transformer for the secondary calculated by the incoming primary feeders of the tranformer, or the secondary? For the branch panel, or distribution panel immediately downstream from the transformer, is the ground calculated by the breaker size of the panel or is it to match that of the ground at the transformer.
Any help would be much appreciated.
