GEL cell batteries are also sealed just like the AGM battery listed above. That is where the similarities end. A GEL battery uses a silica (sand) to turn the sulfuric acid into a jelly like substance. This jelly is then used as the electrolyte. Great care must be taken with GEL batteries not to expose them to high amperage situations. High amperage situations can literally 'SCAR' the jelly inside of a GEL battery, creating a pocket. These pockets allow the plates to begin corroding, leading to premature failure. GEL batteries should not be used for fast charging/discharging, or high amperage charging/discharging situations. Use the other types listed above for these high amperage situations. GEL Batteries are slightly stronger in regards to internal construction than a flooded battery, but pale in comparison to the physical strength of an AGM battery.
