megawatt
- Central Kentucky
I'm bidding a job for a Portable Generator hookup. Probably 60 KW. Mounted on a trailer.
This Gen will be moved to different locations on this Horse Farm, and also used for irrigation, and other various needs.
To power the main house,
I'm planning on installing a service rated, 400 amp manual transfer switch on the residence.
What I'm looking for, is a separate 3R inclosure that the Owner can wire into...I know they won't call an EC every time the power goes out, & I don't want to see them opening up an energized transfer switch to hook it up.
With this inclosure, I plan to extend the Gen connections, outside of the transfer switch.
I thought someone else may have run across this situation before, & found something that made a nice install.
Just looking to make it as safe as possible! Thanks in advance.
