I think I have read this here before but I can’t find it so I’ll ask again.
I have a Generac 100A ATS installed. I am supplying it with a portable generator 30A when power goes out (only supplying basic items to not overload the generator). My question is how do I make the ATS switch the solenoid to generator power once I start the generator?
There is a 12v battery tender the previous owners had installed which appears to be powered on when the generator is started (not sure it’s getting power from the correct location when the generator is on) and then should give 12v+ and 12v- to the generator ATS I assume similar to the control brain on a true standby generator. Should the 12v+ go to go to the “customer connection” +12VDC and the 12v- go to the transfer #23 to activate the generator service solenoid when line service is lost?
Currently to transfer power I have to remove the cover and use the included rod to pull the switch into generator mode.
Thanks.
Thanks.
