FREEBALL
- york pa usa
I installed a generac 22kw and ATS w/ load shedding in a commercial setting. I want to now further shed some load without the load shedding modules. I am using 120 v contactors to shed some load but the panel Im designating the generator panel has 9 shorelines for ambulances. I would like to run from the line side of the sensing fuses on the ATS, a 120v circuit, fuse it at 2 amps in the ATS, to hold a set of contactors that would feed the shorelines from the panel. The panel is 110 ft away from ATS. So when the power drops out, the generator comes on the shorelines will not be powered. Does this sound viable and does anyone else have a better idea. I thought of using sort of a manual shunt that when the power goes out the shorelines would need to be reset, but there may not be personell on site at that time to manually reset.
Thanx again for any insight.
