FREEBALL
- york pa usa
Anybody have or used this portable generator im ready to pull trigger on it and cant find solid reviews
Thanx jeff
Thanx jeff
I have a customer that has been using a pair of 15000E for several years. They have insulation blowers set up in enclosed trailers they use on job sights. AFAIK, no problems.Anybody have or used this portable generator im ready to pull trigger on it and cant find solid reviews
Thanx jeff
I have two at a day camp facility. One is used to back up 1/2 of an admin bldg. and the other for a cooking pavilion. Performance wise they've held up pretty well but the facility doesn't maintain them. Both have a considerable amount of rust and have been resurrected a few times in desperation. My only complaint came at one point in time when they called me in because the unit wouldn't start. I looked and looked and looked but couldn't find a reason for the malfunction. Finally I thought "maybe there's a fuse". So I started looking and couldn't find one so, I began removing the control panel cover only to find a plug-in fuse located on the back side of the compartment. Hell of a design !!!:rant:
Anyway, if you truly need the 50A, 120/240V output it will perform for you. However, read through all the specs on the unit and make sure it fits your needs.
