Generac standby generator problem
steadyed21
New User
Johannesburg, Michigan
Retired
My Generac Whole house standby generator will shut down once in a while during weekly run cycle. It gives me a error code of 1300 which is a oil pressure problem. This does not happen often. Maybe 3 times in last 6 months. I go out to reset and start it manually and it starts and runs fine. Has always kicked in during power outages. The unit is only 1 1/2 years old. I suspect a oil pressure switch but why not kick off when I start manually? Oil dip stick reads oil is full. Unit still looks new. should I be concerned. Still under warranty. Never had it serviced but still way under hours for maintenance.
