Generac xp8000e portable generator installation
matt123
Has anyone installed one of these tru power generators recently? It is a fully gfci protected generator that requires a switch neutral harness to work properly which needs to have a transfer switch. It eliminates the ability to use an interlock. Has anyone used something to make and break the neutral/ground bond inside the breaker panel to make this work? Switch or contactor of some sort when the gen is on or off. Thanks,
