General 120v duplex recept
TTwizted
florida
I installed a regular duplex recept, and when I put my plug in tester it says the neutral and hot are switched. Mind u that I have been an electrician for over two years and in school going on my last two years to be a certified electrician lol. So that being said, I know how to wire a recept. I found a jbox in the attic so that's where I jumped the power from. Anyway the weird thing is it is good when my kitchen lights are off but when I turn them on it makes my neutral hot along with my hot still being hot. What could this be?
You probably connected to a switch leg or a traveler of a three way which uses a white wire and was not taped or painted black.
Welcome to the forum. You need to check with a multi-meter to see what's truly going on. Plug testers are ok but have a lot of limitations. I had one tell me I had an open neutral when in fact the breaker was shot and only allowing ~40V thru.
If you truly have hot-hot, you either have 0V across hot and neutral, and nothing plugged in will work, or 240V, in which case it'll work really well for about a second before it goes poof.
