angrymonkey
Hello all,
I have a quick general question on grounding equipment pertaining to "opposite, diagonal corners" that you typically see.
What exactly is dictating the opposing corner grounding plates you typically see on a large percentage of equipment? Is this a blatant NEC requirement I have somehow missed?
Or is it more of a rule of thumb of sorts? Meaning, can code be fulfilled with just one connection but experience dictates a second connection for redundancy and protection in the case of damage problems?
For example, small transformers with a specification that contains the verbage:
"The base of the enclosure shall be furnished with ground pads located on opposite diagonal corners. "
You see this everywhere, so I am just making sure as to what pushes this aspect. Hopefully I am clear as I tend to ramble
