oldbay444
- Birmingham, AL
I'm working on the NAED EPEC program and there is a question I am not 100% sure I have the correct answer for.
Hoping you can lend some of your expertise.
The question reads: "If operating equipment at higher voltages allows the use of smaller conductors, why do we commonly use 120 or 240 volts, or even 12 volts? Why don't we operate everything at, say 480 volts?"
My inital thought is that safety is the main issue. Higher voltage systems tend to have more violent ground faults, and of course the explosive nature of a 480 phase to phase fault.
Additionally, I imagine there is a play here with GFCI and the threshold 30MA being reached faster in a 480V system??? Not sure here.
Anything else I should consider?
Thanks in advance!
Scott
Thanks in advance!
Scott
