M MBLES Senior Member Oct 22, 2018 #1 if I have a retail store 150x100 sqft and the store will have 300 luminaires 2 lamp 120v .75 amps and you had to determine demand load do you add both or larger of the two? IF ANY what is nec code if larger value is used. or if both are added
jumper Senior Member Location 3 Hr 2 Min from Winged Horses Oct 23, 2018 #2 See Annex D, example D3 in the NEC.
