Once the total VA is calculated using the volt/sqft table how is it finished to determine your general lighting load and the number of CB's you will need? Does this include your receptacles?
Example: 2100 sqft home @ 3VA/sqft equals 6300VA
voltage: 120/240 single phase
General lighting load equals 26.25 amps or 52.5 amps, what exact voltage should i use? 120 or 240. This does not include my receptacles does it? Or is this just telling me that I can use 2 15Amp breakers to satisfy my general lighting load? Is there something generic that says how many 15 Amp receptacles are permitted on a 20Amp circuit? In the industry, is it standard practice to wire the receptacles in series or parallel. Thanks for your help, just trying to brush up on things. The military doesn't give me the chance to use my NEC knowledge too often.
Thanks, Chris
Thanks, Chris
