Thomas Stephenson
New member
- Savannah, GA
I find myself in a situation which I cannot satisfactorily explain:
I added a 240 volt HVAC circuit to a fuse box piggybacked temporarily on the range circuit (the service change was scheduled for the following week).
One of the 2 the two main fuses (the fuse to the whole fusebox) blew a few days later. So 120 volt to ground from one leg and 0 to ground at the other leg. The customer reported a fire at the range and the dryer stopped working. The range outlet and the dryer outlet are both 3 wire (no neutral).
My question is is it possible for a blown fuse (dropped leg) to cause a fire in a range, and can that cause a dryer's permanent failure?
I expect that I know the answer, but you may imagine that the customer has lost faith in me and does not trust my answer.
