electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
When installing a back up generator with a separate back up loads panel, do I need to relocate the EGC's and neutrals in the back up loads panel as well? I thought I remember that the code requires the neutrals to land in the same panel as the hots, is that right and if so what is the code reference? Same with the equipment grounds?
Thanks!
Thanks!
