morgan-pe
- Lewisville, Texas
- Sr Project Engineer
Does the NEC says anything about the generator acting as main power feeding two separate loads.
There is no utility power.
I was thinking two separate disconnects will work. The generator is a Capstone. So two set of feeders from the Capstone bus bars, one to each disconnect.
One feeder will be for existing loads, an MCC. Second feeder will be for new MCC.
