Lady Engineer
- New Jersey
Hi all,
I have a new 750KW, 480V/277W, 3ph, 4W diesel generator. The generator breaker will be rated 1200A. The generator is optional standby, as the nursing home already has it's critical and life safety loads on a 600KW generator.
I think I need ground fault on the generator breaker, but the panel that is fed from the generator is MLO and has no breakers rated over 1000A.
Do the ATS that are fed from those breakers need to be 4 pole?
