I am installing a 100kw 120/240 volt single phase generator to a transfer switch. It is NG and max output is 379 amps. Here's my question:
They have a 450 amp breaker on the generator (I ordered as a 400 amp generator), do I size for breaker or the 379 amps it puts out. I wanted to run parallel 3/0 cu to x-fer switch. Can I use the 90C degree column or have to use the 75C column and use 4/0 cu.
Thanks for any help.
