First time wiring up a contactor panel. There are 4, 4pole contactors in a separate panel next to panel 1. Due to structural limitations, 1" conduit is the max that can be run between them, without having to run outside and back in (rears of panels share exterior wall). Only 2 contactors are shown. 5 CAFI breakers run in (one is pictured), Dryer, 2 AC units, Range, 1 sub panel.
What are my options here? I'd like to use the 1" conduit as much as possible
Can the individual grounds be taken care of by the single 6ga, and removed or cut on the Panel to Panel NMs?
Can a common neutral bar be shared as depicted, so long as the single panel to panel neutral is able to handle the combined load? (50a range, 2 30a sub panels) (6awg shown, 4awg calculated)
Suggestions?
Suggestions?
