Hi all. I'm proposing to install a 48 kw Kohler generator ( 200amp) in a existing residential home that is fed by a underground 400 amp service and 2 4/0 seu into basement to 2 - 200 amp main breaker panels.The generator will sit 90 feet away from house. I plan to use a 200 amp (service rated) ats and like to install it in basement beside the 2 panels . Mainly so I don't have to put 2 service disconnects outside . Unfinished basement with plenty of wall space . All protected circuits will be utilizing just 1 of the panels . My questions are ...do I need to install the 200amp generator disconnect outside on house or do I mount it near the generator itself which is 90 feet away . ( if you stand at generator local and look towards house ...the meter is around the corner and not within site ( if that matters) . Do I possibly need 2 disconnects ? . Code book seems vague on this . Any help appreciated.
