RAYMONDK
- Zebulon, NC
The previous thread for this subject is closed so I guess I'm restarting it. Article 445.18 clearly states that if an installation complies with the two conditions that a disconnect is not necessary. This to me means no disconnect required and all the rules for feeders, SE rating, location, and visibility are moot. Why then is there such a deliberation of this topic. A generator which is connected to a system downstream of a main through a double throw automatic transfer switch (condition 2) with an engine kill switch (condition 1) is safe for any situation that can occur naturally. Additional protection for one who mistrusts automatic controls can be gained by simply removing the starting battery negative cable, which is advised by practically all service literature, or one can remove the battery control circuit fuse which is usually located in the vicinity of the starting battery positive terminal. Every enclosed unit I have ever installed has and E-Stop switch which totally disables the generator instantly. I have installed over 100 generators as the Engineer of record, from 20 KW to 2,000 KW and repaired probably 25 or more and have as yet to ever see a disconnect on a generator installed in this way, as most are. Most have circuit breakers to get around the over-current and short circuit requirement, but that is a useless waste since most generators will not sustain the required current to trip one. A generator will do 300% current for a second then it falls down to a lesser number depending on the engine and exciter system. A breaker needs 125% current to trip long time and a normal generator can't provide it unless the current is reactive, which is not typical. I know I'll get bombarded but as a Mechanical engineer with over 40 years of Electrical experience and many rounds with inspections I'll be interested to hear your thoughts. And Yes, it just popped up again.
