Generator error code 1026
Has anyone dealt with a 1026 vscf comms loss on Generac 20 kW synergy generator?
Completed the install last month. Code appeared on initial power up. I figured once programmed it would go away, which it did.
Upon putting it in auto mode realized crossed the utility sensing wires. Corrected this and the generator ran fine during all test, including dropping out main breaker.
customer lost power a few days ago and generator did not run, showed error code above. Called Generac they say it's a internal issue. Since I'm not certified tech do not want to void waranties. They had to contact a certified company to trouble shoot.
Just curious if anyone else has run initial this.
