I'm reviewing the AFC analysis of the previous engineer and have noticed that he only used the utility service transformer AFC for all downstream calculations. We have a (massively oversized) standby generator onsite that also supplies power to all the same locations in the event of an outage. The only place he used the AFC from the generator (which is double the AFC from the utility) is for the ATS panel, however am I correct in thinking that this value should have been used for all downstream calculations as well to get a MAXIMUM available fault current?
