Generator food truck build
Bhoover315
New User
New york
Welder
I have 2 generators driven by one motor for a food truck. Each generator has 4 wires: black and red ( 120v each), white (neutral) and a green (ground). The white and green wires are connected (bonded). When I wired the breaker box inside the truck I wired the left side to be ran by 1 generator and the right side to be ran by the other. The plug that I have is a 4 prong that is wired from the box to an outlet outside of the truck. Both generators are ran by one motor and is mounted to a utility rack on the front of the truck.
1) how can I wire 1 generator with 2 hot wires to 1 wire in the plug?
2) can both generators share the neutral wire? Both generators are bonded.
3) will the frame of the truck be a suitable ground? As long as the stator is bonded it should trip the breaker?
I have pictures and any other information you need. Not sure how to post pictures here but I could email them. Or I'll post them on the Facebook account: Bipolar Express. Any Information, comments or concerns would be much appreciated. This is the last thing I need to figure out before I can open
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
First, the NEC does not cover vehicles such as a food truck. Next, in my state, Washington, a permit and inspection is required for food trucks. We are unable to assist you further as this is a DIY post. Since you are dealing with food, electrical, water, its critical you find a qualifed company to make sure your installation is safe and not a hazard
