No. Not without adding an ignition system and an alternate fuel delivery system (that is, for practical purposes, replacing the engine itself.) NG operation will not allow for diesel ignition of the fuel charge, nor can the NG be delivered through the injectors of the diesel engine.Can a desile generator be converted to operate on NG ? This about a 1500 kw Gen.
At 1500 KW, there probably aren't any natural gas options. Diesel is probably the only way to go.
At about 100 to 150 KW, NG generators get so expensive that anything larger would almost have to be diesel.
And your generator is 10 times larger.
+1Not completely accurate statement.
CAT, Cummins/Onan and numerous other genset manufacturers offer NG/LPG fueled gensets up to 2500KW and some beyond 3000KW.
http://www.cumminspower.com/www/com...caldocument/SpecSheets/LeanBurn/na/s-1623.pdf
http://www.cumminspower.com/www/com...caldocument/SpecSheets/LeanBurn/na/s-1463.pdf
Not a completely accurate statement.
http://cumminspower.com/en/technical/documents
And, that double displacement is also turbocharged!Yes, you are right - they do make natural gas generators that large.
But if you look at the engine displacement for a 1000 KW natural gas vs. a 1000 KW diesel, you will see the NG generator has a displacement twice as large - 60 liters vs. 30 liters.
You can imagine what that does to the price of the generator.
Really large generators that use natural gas as the energy source are typically using the gas to heat a boiler and the steam powers the generator:happyyes:
I believe they call that a "Power Plant"![]()
Yes but is still a natural gas powered generator:happyyes:
The short answer is it may be possible, but will most likely be a cost prohibitive and problematic conversion product.
I have personally known several units that have been converted and none of them have been a cost effective success story and most have been continually problematic with a lot of required maintenance and unscheduled downtime.
Even if you could find a way of providing a spark, in the cylinders, many other problems comes to mind from knowing how a diesel operates, the main one is a diesel has a 20:1 up to 30:1 compression ratio, firing a diesel off gasoline or Propane/NG would blow the heads right off it, seen it happen when someone used to much ether, also a diesel does not have a throttle, the air intake is wide open so a method of controlling the air intake would have to be found, at a 22:1 compression ratio, a diesel would suck most throttle plates right into the engine, ever tried to stop a runaway diesel with a piece of metal, it will suck the metal right into the intake if it doesn't collapse/implode the intake, another problem is lubrication of the upper combustion area of the engine, a diesel depends upon the fuel to lubricate the valves and piston rings as well as other parts of the engine, so this would also be a big problem.
So to even start thinking of converting a diesel to run on NG or Propane, one must figure a way to lower the compression ratio, provide a intake air throttle, and find a way to provide a spark inside of the combustion chamber, so then why not just replace the diesel with a gasoline engine with a NG throttle body, then sell the diesel back to the manufacture or someone who could use it which would cut some of the cost of the new engine.
Many gas turbines can burn many different types of fuels I have heard of many of the larger generators being equipped with gas turbines (basicly a jet engine with an output shaft) just for this reason, but these were for co-gen plants.
