Hello all,
Setting up a EOC (Emergency Operations Center) trailer recently, I ran into a problem where the APC UPS wouldn't accept the "building wiring". The UPS is a APC SmartUPS 800, running not more than a satellite modem and a Linksys router. Running off of a brand new Honda 6KW generator, it would not turn on. Another UPS running 3 laptops did the same thing. I wired the trailer myself, keeping the neutral/ground separate, and running into a GFI. The GFI didn't trip.
With two different meters, I had around 40V difference between neutral and ground, and 60V difference between hot and ground. However, I still had almost 130V between N/G. (normal) But the UPS refused to fire up. Thought it was the new generator, so another was brought in, same result.
Ground rods at both the trailer and gen. Can anyone explain why it is the way it is? I question this, as well as pretty much need an answer, since we are setting up the trailer to run off of both commercial, and various generator power. (depending on situation) I took a chance and hooked up the old LJ-4 printer, without the UPS, and it works, so I plugged in the laptops, and all worked there as well. Just don't know why the V difference is so great. All cords are 12GA 3 wire, longest run of the two is 100'.
Also, the tests were run at the gen, without a load, and the gen outlets gave me the same readings.
I'm not a licensed electrician, but I'm sure I rewired my kitchen to better standards than most contrators, including adding a sub-panel, and having to rewire the bathrooms and laundry room at the same time. (such FUN!) And I may be posting this from my garage, but the house is still there... REALLY!
Thanks in advance,
Doogie
Thanks in advance,
Doogie
