I have a customer that is not connected to the Grid. He has a fixed generator that he will use for his electrical source for his home. My questions are:
1. Does the generator need a ground rod at the generator?
2. Do we need to run a ground wire from the generator to the house panel?
3. Do we treat this as a typical home and drive a ground rod at the house and do the grounding and bonding like its typically done?
Your input is greatly appreciated.
Thank you.
Thank you.
