samuelrock
- Morgan City Louisiana
I have looked through the code for this but cannot make heads or tails,
Option 1
When installing a fixed backup genset should you move the ground from the meter pan to the ATS and then take your 120-0-120 from meter pan to ATS.
at this point your ATS will be your main disconnect and will have a neutral to ground bond. then feed inside with 4-wire and install ground bus bar.
if you do it like this then your neutral will still be connected to the case of the meter pan, thus neutral current can cross over the neutral to ground bond in the ATS and flow across the ATS case to the meter pan and up to the transformer on the pole.
Option 2
I am thinking that maybe you should remove the neutral to ground bond from the ATS and leave the meter pan bonding feed your 120-0-120 to the ATS and then ground your ATS to the #6 comming up from the ground rod with a split bolt.
What option if any is code friendly?
Option 1
Option 2
