I was reviewing a landfill site where a NGR is used to limit fault current at the generator. The generator has a dedicated Y-Y GSU. Since the generator neutral is bonded to ground through the resistor shouldn't the bond between the GSU XO terminal and ground be removed? I noticed that it was installed and it seems that this will negate the protection provided by the NRG? The generator is 1500KW, 480V and step up is to 34.5KV. Start up is next week and want to insure this is correct before proceeding.
Thanks
Thanks
